4th Gen ('81-'88): carb acc pump sol & carb acc pump sol temp sw
Old Apr 12, 2018 | 09:27 AM
Cwcb08's Avatar
Red face carb acc pump sol & carb acc pump sol temp sw
what are the "carb acc pump sol" & "carb acc pump sol temp sw", i am chasing a pink wire with a black trace (#39), from the engine bay, according the wiring diagram they go to the gauges. im also not sure what NM5 is, or if my car has it?
Old Apr 12, 2018 | 12:09 PM
Jeffs02rwdSS's Avatar
Do you have a picture of the carburetor ? I recall a sensor on top of some of the computer controlled carbs.
Old Apr 12, 2018 | 01:26 PM
Cwcb08's Avatar
it is not a CCC, and i don't believe it ever was, model number is 17056228 (17056228 Carburetor Info Page)
Old Apr 12, 2018 | 02:11 PM
Cwcb08's Avatar
didi these cars have modular wiring or was it only specific to what options it had, would i have extra un used plugs in the engine bay?
like the first picture it shows Oil press & oil press sw, i know the line is dashed for the sw, but i have a un used connector in the same area as the Oil press conector ?
Old Apr 12, 2018 | 06:33 PM
Looked at the link for the carburetor and it comes up as a 77 GM carb which probably explains why you don't see the carb acc pump sol. I found a few pics in these links that shows a carb for a 84 and a 86 monte carlo 305 both show the solenoid and.wires going to it.
Old Apr 12, 2018 | 06:41 PM
As for the wiring the factory would use the same harness for the same engine regardless of the options (cruise,air or gauge options) they would obviously have a different harness for a chevy 229, buick 231 , chev 5.0 hope I helped a little.
Old Apr 12, 2018 | 07:23 PM
Cwcb08's Avatar
thank you for the links, that sure looks like the connector, any idea if the Canadian version of the car was identical to the American version? it should it have had the CCC?
Old Apr 12, 2018 | 07:41 PM
Not up much on Canada's emissions but yes it should have had the computer carb on it and the cars were about same otherwise but I Think I remember you saying it's old enough to be exempt so no worries
Old Apr 12, 2018 | 07:47 PM
Cwcb08's Avatar
yes it is exempt, just trying to clean up identify and re connect what was disconnected ( instead of unplugging the AC when the condenser broke they cut every wire >:@ )
Old Apr 23, 2018 | 10:56 AM
DAVESS2002's Avatar
What year is your Monte? It sounds like whoever had it before you removed all of the CCC and smog parts. They added a standard Quadra jet and distributor probably. I have a 1987 El Camino with the CCC carb. The acc sol is the accelerator pump solenoid, so those wires are not needed for a non ccc carb.
