Car won't start. Battery or Starter?
I've got a 1997 Monte Carlo LS with either a bad starter or just bad battery/connection. The car started fine this morning, drove it to work, left work to get gas and it would not start at the gas station. All it would do is "click." Towed it home, looked at everything and decided to give the starter a tap with the hammer, then it started up. I know this is a given sign of a bad starter, but I just want to make sure. When I turn the key on all the dash lights, radio, headlights, etc work. Gonna take it to the local auto shop tomorrow but I want to make sure that's it before I do.
I have to get it fixed ASAP! Any help would be greatly appreciated.
Thanks!
Thanks!
Have you tried to jump start it? If it still goes click click click then it is more than likely the starter. If it starts after being on the cables for a bit then battery if it doesn't start again when you turn it off and come back later then alternator!
If the starter worked after you tapped it with the hammer then the pinion gear is being thrown out into the flywheel but is not producing sufficient torque to turn the flywheel, thus not starting your engine. This is most likely due to sticky/failing bearings inside the motor. Easiest fix, just replace the starter, tapping it with a hammer only works for so long.
Based on the fact you just tapped the starter, I'm inclined to vote the starter as the problem.
You can get dash lights, radio and other electrical devices that work fine and still have a bad or low charge battery. I've had failed batteries cause the starter to only click because they no longer pit out enough power to fully operate the starter.
You can test this a couple ways:
- try jumping the car
- swap batteries with a known good battery (such as from another car)
- pull the battery and starter, have your local parts store bench test then
If you find the problem to be the battery, you still need to ensure you don't have a problem like a bad wire in the charging circuit or alternator.
On modern cars like these montes with a lot of computer controls never pull the poor man's alt test (this would be disconnect the battery while the car is running, this could damage computer equipment in the car).
Have you checked for a loose/dirty connection at the starter motor and the ground cable where it bolts to the transaxle?
Tapping with a hammer releases the jammed bendix gear from the flexplate teeth. This happens when the spring in the bendix weakens or insufficient amperage to rotate the starter. That's why I suggested checking the cables. If all checks out ok you have 2 choices, You can replace the solenoid or the complete starter assembly. Personally, I would replace the entire unit.
6th Gen ('00-'05): monte carlo won't start immediately after installing new battery
bonzolead
Feb 26, 2015 10:15 PM
3rd Gen ('78-'80): Starter Solenoid for Summit SUM-G1660 Mini High-Torque Starter
rmorman
Oct 24, 2013 06:32 PM
ladybridgeport
Mar 19, 2012 09:14 AM
ChevRev34
Feb 24, 2008 01:10 PM
