Car won't go above 3000rpm
I have a 96 z34 and it has 123,000 miles on it. Today it would not go over 3000rpms and when it got to 3000 there was a knocking noise that sounded like it was below the pedals. I just changed all the plugs in it. If you guys have any ideas on what it could be, I would greatly appreciate it.
One troubleshooting principle that I always try and adhere to is look at the last thing I did - in this case plug change. Any chance of crossed wires? Was it running fine before the change? You don't have a rev limiter do you? I'd recheck the wiring and make sure the firing order is correct...and that all the plugs are fine and gapped correctly....
