Car won't go above 3000rpm
Old Mar 10, 2014 | 02:55 PM
Jake Robinson's Avatar
Default Car won't go above 3000rpm
I have a 96 z34 and it has 123,000 miles on it. Today it would not go over 3000rpms and when it got to 3000 there was a knocking noise that sounded like it was below the pedals. I just changed all the plugs in it. If you guys have any ideas on what it could be, I would greatly appreciate it.
Old Mar 10, 2014 | 04:13 PM
Viperpit's Avatar
could be a clogged cat or tranny solenoid
Old Mar 10, 2014 | 04:26 PM
phuntley's Avatar
One troubleshooting principle that I always try and adhere to is look at the last thing I did - in this case plug change. Any chance of crossed wires? Was it running fine before the change? You don't have a rev limiter do you? I'd recheck the wiring and make sure the firing order is correct...and that all the plugs are fine and gapped correctly....
Old Mar 10, 2014 | 08:00 PM
This in gear or in park/neutral? as there is a rev limiter, but its closer to 4k.
SolowSS
Oct 20, 2018 02:54 PM
Plengr
Dec 23, 2010 09:51 PM
red04montels
Mar 3, 2010 07:36 PM
Groucho
May 28, 2009 06:48 PM
mickey
May 16, 2007 08:33 PM
