Car not starting issue
I have a 2001 monte SS. Every 2-3 days or so my car wont start. From the research I did, its a common passlock problem. The way I get around it is by putting the key on the 'On' position for 10 minutes then turn the key off then on again and it starts
Can someone please tell me what part(s) I need to get in order to fix this problem?
Any help would be great.
That should fix it.
The guy that replaced mine took out most of my dash getting to it.
You'll have to go through the security relearn procedure the first time to get it to start - it's three of the ten minute waits, but don't try to start until after the third time, it should start then.
