2000 Monte Carlo multiple misses
Old Oct 8, 2013 | 11:02 AM
Meadsy69's Avatar
Default 2000 Monte Carlo multiple misses
Ok so last night on my way home from work. Car ran great until I started to turn a corner and lost all power. Sat on the side of road for a couple hours and finally got the car to start but was missing like crazy. I limped stage car to autozone and hooked the obd2 scanner on it and was getting multi miss reads so I bought new coil packs wires and plugs changed all of them in the parking lot and still no change on miss fire at this point I'm lost this is my first Monty or even first Chevy what do you guys think the problem is..
Old Oct 8, 2013 | 11:25 AM
JC Colon's Avatar
Have your Ignition Module checked. Normally they just stop working and the car just crankes. But it and your computer are the only other links in your ignition system. You could Also have a clogged Cat or a Vacuum leak. All these are worth checking. Hope this helps.
tweek
May 3, 2015 12:23 PM
green98
Jan 24, 2015 04:37 PM
DChronos
May 16, 2011 02:19 PM
menaja19
14
Jan 2, 2008 09:21 PM
miklin83
Apr 30, 2006 03:05 PM
