Can anyone tell me what part this is? (3800 Engine)
Old 05-17-2011 | 09:18 AM
jdawgkemp's Avatar
Default Can anyone tell me what part this is? (3800 Engine)
Looks like some type of vacuum port. The 2 lines got disconnected somehow and Im trying to figure out how to replace this...
Old 05-17-2011 | 09:57 AM
Hi Jarrod,
What year is the 3.8L ?
Check back on your thread question, & I'm sure one of our expert member's will be able to help...Good Luck 4-Sure.
Old 05-17-2011 | 10:28 AM
Kozentaru's Avatar
They are vacuum lines. I think one of them goes to the fuel pressure regulator, not sure where the other goes though. Someone correct me if i'm wrong though.
Old 05-17-2011 | 10:37 AM
JaxJim's Avatar
I think this diagram is correct for your car .....Hope it helps. Also, check to see if there's a diagram sticker under the hood anywhere. My 3.8 is at home or I'd lift the hood and check mine.
Old 05-17-2011 | 10:43 AM
nitehawkjcb's Avatar
If the L36 is the same as the L67, then that one goes to your evap (on the back of the motor, over the exhaust manifold)
Old 05-17-2011 | 11:00 AM
Just wanted to thanks our member's for helping another member with their problems/questions.
It's member's like above that are the backbone to our forum & I just wanted to sayThanks to all that help others...
It is appreciated by all that need help & that learn from you sharing your experience & auto knowledge...
We may 4-get to say thanks in our busy life trying to survive in this crazy world..., but it's always great to see/read 4-Sure. Thanks from the MCF Staff
Old 05-17-2011 | 11:03 AM
JaxJim's Avatar
Check out some of the parts diagrams on this web site - maybe you can find the part and #.
TUBE. Early Fuel Evaporation (24504768)
Old 05-17-2011 | 11:20 AM
It's a vacuum line and I just replaced that "assembly" on my Monte ($35 from the dealer, comes with the two hard plastic lines and all the rubber pieces). I could have fabricated stuff to make it work, but I wanted a clean factory look.
Old 05-17-2011 | 12:47 PM
BlownUptoHigh's Avatar
Can't you just push both of those lines back in. When i was messing around trying to replace the thermostat i accidently disconnected the bottom one and just pushed it back into the main one that connects to the car
Old 05-17-2011 | 12:51 PM
jdawgkemp's Avatar
Thx for the advice guys. BlownUp theyre actually broken off like they were a complete assembly.
Maniac I'll go by the dealership as soon as I can.
