Can anyone tell me what part this is? (3800 Engine)
Old May 17, 2011 | 08:18 AM
jdawgkemp's Avatar
Default Can anyone tell me what part this is? (3800 Engine)
Looks like some type of vacuum port. The 2 lines got disconnected somehow and Im trying to figure out how to replace this...
Old May 17, 2011 | 08:57 AM
Hi Jarrod,
What year is the 3.8L ?
Check back on your thread question, & I'm sure one of our expert member's will be able to help...Good Luck 4-Sure.
Old May 17, 2011 | 09:28 AM
Kozentaru's Avatar
They are vacuum lines. I think one of them goes to the fuel pressure regulator, not sure where the other goes though. Someone correct me if i'm wrong though.
Old May 17, 2011 | 09:37 AM
JaxJim's Avatar
I think this diagram is correct for your car .....Hope it helps. Also, check to see if there's a diagram sticker under the hood anywhere. My 3.8 is at home or I'd lift the hood and check mine.
Old May 17, 2011 | 09:43 AM
nitehawkjcb's Avatar
If the L36 is the same as the L67, then that one goes to your evap (on the back of the motor, over the exhaust manifold)
Old May 17, 2011 | 10:00 AM
Just wanted to thanks our member's for helping another member with their problems/questions.
It's member's like above that are the backbone to our forum & I just wanted to sayThanks to all that help others...
It is appreciated by all that need help & that learn from you sharing your experience & auto knowledge...
We may 4-get to say thanks in our busy life trying to survive in this crazy world..., but it's always great to see/read 4-Sure. Thanks from the MCF Staff
Old May 17, 2011 | 10:03 AM
JaxJim's Avatar
Check out some of the parts diagrams on this web site - maybe you can find the part and #.
TUBE. Early Fuel Evaporation (24504768)
Old May 17, 2011 | 10:20 AM
It's a vacuum line and I just replaced that "assembly" on my Monte ($35 from the dealer, comes with the two hard plastic lines and all the rubber pieces). I could have fabricated stuff to make it work, but I wanted a clean factory look.
Old May 17, 2011 | 11:47 AM
BlownUptoHigh's Avatar
Can't you just push both of those lines back in. When i was messing around trying to replace the thermostat i accidently disconnected the bottom one and just pushed it back into the main one that connects to the car
Old May 17, 2011 | 11:51 AM
jdawgkemp's Avatar
Thx for the advice guys. BlownUp theyre actually broken off like they were a complete assembly.
Maniac I'll go by the dealership as soon as I can.
