Opinion Needed: Caliper guide pins
Old Mar 8, 2016 | 03:38 PM
Scott_S's Avatar
Default Caliper guide pins
While changing brakes today, I noticed the PO used anti-seize on the guide pins. Would it be alright to clean it out of the bracket with brake cleaner and replace with silglyde which I prefer ? Or would it be better to just top it off with more anti-seize ? I'm not sure if anti-seize plays nice with other greases, if I can't get it all out.
I have a little while to think about this. I'm doing the rears today and the fronts tomorrow due to time constraints.
Old Mar 8, 2016 | 03:54 PM
I have used antiseize on the pins before, never an issue. I have also wiped antiseize off, regreased with caliper grease and reinstalled, no problem.
I only replace the pins if I suspect they are damaged or they look bad (such as a head rounding off).
Important note- the bolts that hold the caliper bracket to the spindle, use a dab of red thread lock!! That is per the shop book and experience from a guy who had a bolt pop off from there. The caliper pins do not require thread lock.
Old Mar 8, 2016 | 04:31 PM
Scott_S's Avatar
Thanks for the quick reply. I'll save the antiseize for the rotor hat/hub face and use silglyde
I didn't know about the threadlocker. I'll have to get some tomorrow. I generally tighten them to about 100 ftlbs (with the 4 door monte, impala) . I never had a problem with that, but I don't want to chance it either.
Old Mar 8, 2016 | 06:39 PM
KCFITZ78's Avatar
Always good to have around..... jar of anti-seize. Cost anywhere from $7 to $10 at Harbor Freight, Home Depot, Lowes and Meijer.
