A/C Woes
Old Apr 8, 2008 | 04:14 AM
rysZ34's Avatar
Default A/C Woes
So on my '99 Z34 the A/C doesn't work. Which is a HUGE problem, except when I want to drive on the highway and don't want the windows down. lol. I'm told that the compressor isn't kicking in at all---could that be just the clutch, or the whole compressor and clutch?
Old Apr 8, 2008 | 12:27 PM
GrandPaDave's Avatar
Default RE: A/C Woes
ORIGINAL: rysZ34
You could have a microscopic leak and all the coolant pressure is gone. Gotta take it to a mechanic to do a system test.
Old Apr 8, 2008 | 03:00 PM
rysZ34's Avatar
Thanks for the response, I'll definitely take it in and see!!
Old Apr 9, 2008 | 05:22 PM
blazerman3's Avatar
Hey Ryan, one thing ya can do is look at the schrader valves where the A/C is serviced. Sometimes the valves back out a little and will leak out the refrigerant. Look and see if it`s oily in these areas. If so take a schrader valve tool and tighten them.But being it`s not coming on you probably need it evacuated and reserviced to get out the moisture.
Old Apr 9, 2008 | 07:17 PM
rysZ34's Avatar
Thanks for the tip! I will probably get it serviced when summer is more near. I appreciate your guys' tips and help!
rysZ34
Jan 21, 2012 07:33 PM
rj
Sep 2, 2010 11:23 AM
coreyeroc
Aug 31, 2009 05:19 PM
rgant_19
Feb 9, 2009 08:09 PM
God_Bot
Jan 28, 2008 04:55 PM
