A/C only works on 5
Ok Mona has been acting crazy lately like blowing warm air then cold but now the ac only works on 5 and its blowing cold like it should. 1 through 4 do activate the radiator fans but cold air just comes out with no force, like opening a freezer. I dont know what to do please help! By the way it is a 2002 SS
ok then it shouldn't be a problem with the air conditioning unit itself. So that means its the blower, i had a similar issue in another vehicle and it was the blower resister pack. Speed 5 should run straight from the fuse box, speeds 1-4 have to go through the resistor pack to slow it down. Thats my guess, maybr someone with some more knowledge can confirm.
Ok I got the blower resistor out and its a little black and half of the chip cracked when I barely touched it lol. It was a pain to get out!!! Im leaving to work out of town as im typing this so I wont be able to replace it until next weekend. I will keep you guys updated... Thanks for the help!
6th Gen ('00-'05): heater only works and stuck on defrost.
Lalozx
May 19, 2015 08:20 AM
6th Gen ('00-'05): A/C only blows hot air from both sides only
Raider
Jun 18, 2014 11:15 PM
No they dont work... Thanks for the fast reply!
