6th Gen ('00-'05): A/C being weird.
Old Oct 10, 2014 | 06:57 PM
voltron005's Avatar
Default A/C being weird.
What would be causing my A/C to blow cold on the passenger side and warm on the driver side in my '01 monte carlo??
Old Oct 10, 2014 | 09:02 PM
Aerocoupe86's Avatar
Monte Of The Month -- November 2016
The actuator motor down under the dash has prob bit the dust. There's one for each side, not expensive but a little of a pain in the sack to change but nothing a few 4 letter words won't ease lol
Old Oct 11, 2014 | 12:24 PM
Viperpit's Avatar
It may not be the actuator. I had the same issue, it was low on freon. $30.00 later i had ice cold air from both sides again. have the shop check your freon first!!!! Our cars are known to blow hot on drivers side when low on freon
Old Oct 11, 2014 | 01:00 PM
mine did the same and the driver side actuator was bad. blow cold as ice out passenger vents. the hot/cold slider for driver side wouldnt change the temp for driver side. the actuator motor for the door was stuck. If it blows good and cold out one side freon level shouldnt be a problem. If semi cool, then yea i can see freon being low.
Old Oct 12, 2014 | 01:52 AM
voltron005's Avatar
Thanks for the input! I'll be sure to check that out and see if it is the problem.
One Dark SS
Apr 13, 2011 09:22 AM
MCF Website Problems & Issues
Jan 26, 2010 09:37 PM
scc24540
Jun 5, 2008 09:01 PM
mavrickf1613
Mar 29, 2008 01:47 AM
mavrickf1613
Mar 26, 2008 12:50 AM
