ABS being weird
Old Apr 12, 2011 | 11:19 AM
One Dark SS's Avatar
Default ABS being weird
What ever actually makes the ABS kick on (applies, releases the brakes quickly) has been acting up the last few days... I've felt and heard that vibration that you would normally feel when the abs kicks in without even applying the brakes, actually keeping my foot on the throttle...
Anyhow have any idea where to start with this? could it be a bad speed sensors? should i be concerned that my abs are going to totally go on me?
Old Apr 12, 2011 | 11:31 AM
Yes, most likely a hub speed sensor is dirty or going.
Old Apr 13, 2011 | 09:00 AM
is there a somewhat "easy" way to isolate which ever one it might be?
Old Apr 13, 2011 | 09:21 AM
just called GM, they can figure it out rather quickly, so i'll just drop it off on Monday
Thanks Chibi!
Old Apr 13, 2011 | 09:22 AM
ABS light will throw an ABS code (not readable with a standard OBDII scanner) and that should let you know which assembly it is.
voltron005
Oct 12, 2014 01:52 AM
robknight13607
Jul 16, 2013 05:51 PM
irulesoha
Aug 19, 2010 02:32 PM
mavrickf1613
Mar 29, 2008 01:47 AM
mavrickf1613
Mar 26, 2008 12:50 AM
