burning oil
Old Jun 4, 2011 | 09:51 PM
monte man's Avatar
Question burning oil
hey im new to this site but i really enjoy reading all the stuff guys put on here i have a 97 monte with the 3400 in it the motor and tranny both have 213k on them and im burning oil i know it coul be time for a new motor but i need to make this one last till i can get the new motor i was told it could be the pvc valve but i have never done one befor so i was hoping someone could tell me where it is and also maybe some other suggestions on how to fix the oil burning
Old Jun 7, 2011 | 11:48 PM
DerEin's Avatar
Need some more information then that. Does it only burn when you accelerate? Is is slight but constant? Maybe a dense fog that chokes other motorists? Is there coolant in your oil or vice versa?
It could also be a number of things, maybe your O-rings are burned out, in which case you are pretty much screwed.
Old Jun 8, 2011 | 06:23 AM
milrlyt's Avatar
Like DerEin said, it could be a number of things. In my old '96 LS, however, I had the problem of coolant leaking into the oil...
Old Jun 8, 2011 | 08:22 AM
monte man's Avatar
well it has the burning oil smell that chokes everyone behind me and it seems to burn oil if its just running i was told it could be a bad vaccume in the crank case so i need to change the pvc valve and i have never done one and im not excatley sure where to find it. there is no oil in thew coolent in the oil or vise vresa but it is frustrating and i had autozone run a dos test on it and it said the car wasnt moving even though i drove it out of the paking lot lol any other ideas guys or can you help me locate the pvc
Old Jun 8, 2011 | 09:21 AM
I am not 100% on the 3400 but on the 3800 the PCV valve is simply just unplug, twist and it pops out and you replace. Piece of cake maybe 5 minute job.
If you are burning the oil through your exhaust then you have a problem where the leak is going into the engine.
If you smell it because it is burning off your exhaust manifolds, your valve cover gaskets could be shot.
Bego
Nov 10, 2009 10:41 AM
freeguy555
Apr 6, 2008 07:17 PM
freeguy555
Apr 6, 2008 07:02 PM
jd5419
Nov 27, 2006 12:09 AM
mymonte
Nov 22, 2006 10:50 PM
