1st Gen ('70-'72): Bulkhead Electrical connection wiring diagram
Hey Gang - does anyone have a link to an electrical diagram for the bulkhead connector for a 1972 Monte Carlo? My manuals just don't give the information I'm needing. Specifically, the wiring out (into the engine compartment) - the color codes and destinations of the wires, etc. referenced to the bulkhead pin location. Thanks bunches for any and all help. Wade.
Well, I had to leave the forum and go back to the shop to work on stuff and then to town with the wife and just now checking the posts - and I find no one has responded - surely someone has the diagram out there in Monte Carlo land??
I am having the same problem
I cant seem to find what is being called the "Voltage reg" on my 72. Its attached to the drivers side firewall with many of my main wires connected. I do have a wiring basic diagram for the 1st gen ..I will try n copy out of the old book for you. Give me a day or 2 .
Thanks,
Joz
Thanks,
Joz
Thanks for your help. You can send that diagram to: wades@mountainmanmotors.com
I have all the basic diagrams - I need the one that shows the thru the firewall connector wiring. That would be awesome.
Thanks again.
Thanks again.
hi just joined . I have a 72 also but having issues with my brake lights. Replaced everything , sockets, turn sig switches, fuses, brake switch and everything works except brakes ! when you mention voltage regulator i thought hmmmm could that be something to look at?
Thanks
Mike
Thanks
Mike
94wrangler4.0
Aug 18, 2011 07:19 PM
PuppetMaster
May 26, 2007 01:25 PM
