6th Gen ('00-'05): Break lights not working
Old Mar 10, 2014 | 11:21 PM
Default Break lights not working
Ok my break lights are not working and the traction control light keeps coming on. I know I need a new wheel hub for the right side. Could this be causing the fuse to keep blowing everytime I put in a new fuse then hit the break pedal or is it something else. Then on the relay below the fuse that I am pointing to in the picture the relay is burnt and melted on the bottom as shown.
Old Mar 11, 2014 | 09:07 AM
owens91's Avatar
if that relay was burnt on the connections i would deff replace that. could be the reason
Old Mar 11, 2014 | 09:20 AM
I did change the relay and it did the samething. This is the second relay I put in.
Old Mar 11, 2014 | 09:26 AM
owens91's Avatar
its possible you might have bad wiring somewhere along, my heated seats does something similar to this, i just put in a bigger amp fuse and its a temp fix. dont know id that will apply here but hopefully one of the members who is better at wiring could possibly help better
Old Mar 11, 2014 | 11:54 AM
Thanks I will see if that will fix it for right now so I can have break lights.
Old Mar 11, 2014 | 12:29 PM
Out of curiosity, in the first pic, why does it look like a wire is being jumped into a relay?? That might be related to blowing fuses and burning things out.
FYI - Moved to Monte Carlo Repair help.
Old Mar 11, 2014 | 02:33 PM
The wire that is for my leds I have had that in there since I got the car a year and a half ago.
Old Mar 11, 2014 | 10:30 PM
So I don't think it has to do with the wheel hub because I unplugged it just to see what would happen and it still does that. With a bigger fuse that doesn't work either. The fuse doesnt pop but still the break lights do not work.
Old Mar 14, 2014 | 01:04 PM
The Dad's Avatar
Have you checked the brake light switch at the pedal? I had mine break in my Chevy Truck once before and that was the reason.
Old Mar 14, 2014 | 03:38 PM
OK, but you may want to look into a better wiring setup then pressure fitting it with another relay/fuse. Even if it's not the cause of a problem now, it might be in the future.
