brakes
Old Jul 8, 2008 | 12:35 PM
Bart's Avatar
Default brakes
I have a 06 MCSS has 20000 miles and the brakes squeal really bad the pads have over 75% pad left anyone have any sugestions on how to make this stop?
Old Jul 8, 2008 | 03:45 PM
rysZ34's Avatar
Default RE: brakes
Readjust your squelch tab on the pad. Or take brake clean and spray your rotor and get any dust out of your pads...LET IT DRY BEFORE YOU DRIVE. )
Old Jul 23, 2008 | 05:35 PM
04 Intimidator's Avatar
Default RE: brakes
X2. The brake tab will be an easy fix. The brake cleaner should be dried by the time you put the can away in the garage and get in the car.
Old Jul 23, 2008 | 07:11 PM
05monte203's Avatar
Default RE: brakes
Ive been having the same problem with my 05, my brake pads and rotors are good, everything is cleaned and lubricated, and my brake tabs arent in the way, but it only sqeals at first then lets off, any suggestions???
Old Jul 24, 2008 | 08:08 AM
rysZ34's Avatar
Default RE: brakes
you may have dirt imbedded in your pad. do you have any grooves on your rotors?
Old Aug 10, 2009 | 01:52 PM
jimbo7's Avatar
i'm having this exact same problem. once the rotors get a little heat in them they stop squealing. it's sooo annoying! my pads has plenty of life and the tabs aren't even close. i sprayed em off with brake cleaner so i'll see if it worked the next time i drive.
Old Aug 10, 2009 | 01:58 PM
Rust on the rotor can be the culprit also. Those good 'ol OEM things...
Old Aug 10, 2009 | 02:07 PM
RickAKATed10's Avatar
Photobucket
OMG his name is Bart!
Old Aug 10, 2009 | 02:09 PM
lmao, he's also from 2008
Old Aug 10, 2009 | 02:56 PM
Budsjlm's Avatar
pull your pads out and see if there is any grease between the pad and the caliper...if not trow a little on the back of the pads.. vibrations between the two can cause this...greese will help
mdowie
Jun 8, 2006 05:21 PM
ralphtrent
Dec 14, 2005 12:09 AM
Scooze
Oct 20, 2005 03:58 AM
Matthew
Jun 19, 2005 03:25 AM
Juve
Dec 1, 2004 12:46 PM
