7th Gen ('06-'07): Brake noise
Old Aug 22, 2021 | 09:38 AM
SSblack06's Avatar
Angry Brake noise
When i do a hard stop i hear a light mental scraping noise. On light stop i do not hear it.
Does anyone know what that is?
Old Aug 22, 2021 | 01:21 PM
Could be pads needing to be replaced. There is a metal tab integrated into the pads for this specific reason. You should hear it during all stops tho. Maybe youre just getting to the point of contact.
Old Aug 22, 2021 | 05:59 PM
I'd pull the calipers off and take a look at things. Its going to be hard for us to diagnose a noise like that remotely with no additional info about the situation.
Old Aug 22, 2021 | 09:27 PM
SSblack06's Avatar
Thank you!!!!
Old Aug 25, 2021 | 04:40 AM
SSblack06's Avatar
Default Brake noise fixed!!!!!
I located the noise. It was the drivers side front wheel. I removed the caliper and pads. Clean everything and lubed the slide pins. When I disassembled the brakes, one of the guide pins was frozen. I resurfaced the pads wiped everything down, and reassembled the brake and noise fixed? THANK EVERYONE 😊 WHO RESPONDED!!!!!!!!!
Stencil
Sep 5, 2011 01:58 PM
pizzarrhea
Mar 9, 2010 01:02 PM
southerncash
Feb 28, 2010 12:47 PM
5207234w
Jan 26, 2009 11:42 AM
PsuBrock
Feb 9, 2008 11:05 AM
