Noise from under the hood?
Old Aug 26, 2011 | 01:05 AM
Stencil's Avatar
Default Noise from under the hood?
Hey, I was driving my car to work tonight and I heard a noise under the hood. It only happens once in awhile when you accelerate or brake, and sorry if this is in the wrong spot i didnt really know where to ask it at. Thanks!
Old Aug 26, 2011 | 01:33 AM
nitehawkjcb's Avatar
What did it sound like? Squeak? Creek? Bang?
Old Aug 26, 2011 | 09:26 AM
zipper's Avatar
Yeah, you're being a little vague Stencil. It could be a number of things, but if it's ticking at all, then check the oil. Don't let that run low.
Old Aug 26, 2011 | 11:44 AM
Stencil's Avatar
Sorry its just kinda hard to explain. Its kinda like the noise of bottoming out. Its like a scrapingish noise. My oil is good, it will just make this grinding scraping noise when your stop or let off the brake.
Old Aug 26, 2011 | 12:20 PM
Sounds like you need to check your brake pads & rotors
Old Aug 26, 2011 | 01:13 PM
superrod29's Avatar
ya seems like your ginding the metal from the pad on the rotor but idk about the acceleration part... could be your dust shield rubbing in your rotor or it "possibly" might be a really bad wheel bearing
Old Aug 26, 2011 | 02:05 PM
Is it possible it is a worn or broken motor mount? Also could it be a bad ball joint or tie rod.
Old Aug 26, 2011 | 04:04 PM
Id say either brakes or wheel bearing
Old Aug 28, 2011 | 01:10 AM
superrod29's Avatar
yea i just swapped my bad bearings with new ones and you wouldnt beleive the difference these make!!! timken bearings are awesome!
Old Aug 28, 2011 | 02:05 AM
Sweet so u got ur issue fixed
