1st Gen ('70-'72): Brake lights do not work
Old Jul 13, 2020 | 06:23 PM
Kchristianson93's Avatar
Default Brake lights do not work
So I'm working on my uncle's 72 monte carlo. His break lights do not work all of a sudden. We replaced the rear light harness, as well as installed a new brake switch and also turn signal switch. I have 12v coming from the fuse to the brake switch and leaving it, but only when I have the turn signal switch disconnected. As soon as I connect the turn signal switch I lose 12v on the white wire coming from the brake switch as well as the orange feed wire. All other lights work perfectly fine and I've read as much as I can find on here referring to the brake lights. Does anyone have any insight as to why I would be losing my voltage when I hook up either the new or old turn signal switch?
Kchristianson93
Jul 13, 2020 06:11 PM
randbement
Jun 21, 2017 10:52 PM
TheConcreteGuy
Feb 22, 2015 06:12 PM
Sanpaoul12
Oct 4, 2014 09:37 PM
m2chv998
Jul 11, 2013 08:27 AM
