brake lights not working
Old Jun 4, 2010 | 10:26 PM
randbement's Avatar
Default brake lights not working
I have a 99 Z34 that the brake lights work part time. It seems that when I first get into the car and start it up they work fine until I'm driving down the road and use the turn signals then they quit. The turn signals work fine and the third brake light works. Any idea what I need to check?
Old Jun 4, 2010 | 11:20 PM
nitehawkjcb's Avatar
Check the bulbs, make sure there's a clean connection. If that doesn't work, it's probably your multifunction switch going bad.
Old Aug 2, 2014 | 09:59 AM
diamondgirl12550's Avatar
Sounds like your multifunction switch located in the steering column. Same thing happened to my 99 monte carlo...had switch replaced...fixed the problem
Old Aug 3, 2014 | 02:21 PM
englundjd's Avatar
yea, i would agree with the multifunction switch also
Old Aug 3, 2014 | 04:00 PM
Mines starting to the same thing...
Someone pointed out that mine was failing...
Its a common problem for 1999...
We had to replace it in my wifes 1999 Blazer as well.
Old Jun 21, 2017 | 06:40 PM
greedy's Avatar
Default 1980 monte carlo
my taillights dont work, headlights works just fine
Old Jun 21, 2017 | 10:52 PM
You might want to start a new thread, this one is old, and for 95-99 Monte Carlo's...
Check the harness to ensure it's getting power to the bulbs. Do the brake lights work when the brake is pressed?
jworm98
May 14, 2017 03:59 AM
dtesgue
May 17, 2012 09:17 PM
bitsy5085
Mar 14, 2009 05:14 PM
thedude
Sep 1, 2006 10:26 PM
