1st Gen ('70-'72): 72 brake light issue
Old Jun 25, 2013 | 06:58 PM
m2chv998's Avatar
Default 72 brake light issue
Replaced sockets, turn signal switch, bulbs and brake switch. Everything works except brakes. Help
Old Jun 26, 2013 | 09:22 PM
TheMonteMan's Avatar
have you tried testing the socket with a test light while having somebody hit the brakes? also is the hazard lights the same as the brake lights? if so do they work? i dont know about the first gen montes but i had a buddy with a early 90s camaro(i know totally different car) having a brake light issue and it had to do with the actual switch under the pedal not bottoming out. i know you said youve changed everything but a second look is always good.
Old Jul 4, 2013 | 12:16 PM
m2chv998's Avatar
Thanks I will ill probably replace the hazard again.. i noticed on the turn signal switch i replaced there is 2 copper contacts, one was folded over the other, they should be separated right? Thanks I will recheck that brake light switch
Old Jul 4, 2013 | 01:25 PM
If the bulbs work....
Check all your grounds!
Have you checked the fuse?
Old Jul 10, 2013 | 08:06 PM
iceman5's Avatar
Sounds like a brake light switch to me. If all of the turn signals and such are working, then the sockets and grounds should be fine at the sockets and with the wiring. The switch may not be bad, but it may need adjustment. It's been awhile, but I believe the switch threads into the pedal housing. You could try adjusting the depth of the switch first to see if that makes a difference.
Old Jul 11, 2013 | 08:27 AM
m2chv998's Avatar
Default Brake light issue
i must be missing locations of the grounds. where should i be looking? the most common ground location
matthew41
Jan 25, 2015 11:22 AM
hotrodharley
Nov 15, 2013 11:37 AM
heartbeat
Jan 14, 2012 10:47 PM
matrx10503
RWD Tech Guides '70-'88
Dec 29, 2011 10:33 AM
giblet78
Aug 11, 2009 05:26 PM
