Brake convertions
Brake convertions
hello just purchued a 01 Monte Carlo SS with 17" wheels and would like to upgrade to larger brakes front in rear. the kits are very pricey There was some talk that i can use camaro parts for the front how much larger would the setup be if so what years and what parts should i get from wrecking yards and part store also what would i use for the rear lmk
You can use F-Body calipers on the front, but that only gets your 2 piston calipers, and saves you some weight. It's not a size upgrade.
All the size upgrades are expensive. I don't know much about the rear swaps.
Only real cheap options would be to find a GXP Grand Prix & pull its brakes it has 12.7" fronts & 12" rears but the front Camaro caliper swap is pretty good i done it to mine & it stops great
Or purchase the ZZP kit that allows the bolts to be used: ZZPerformance - FBody Caliper Install Kit #ZZ-FBCALKIT
