Brake convertions
Old Mar 2, 2012 | 08:56 AM
elkzzilla's Avatar
Default Brake convertions
hello just purchued a 01 Monte Carlo SS with 17" wheels and would like to upgrade to larger brakes front in rear. the kits are very pricey There was some talk that i can use camaro parts for the front how much larger would the setup be if so what years and what parts should i get from wrecking yards and part store also what would i use for the rear lmk
Old Mar 2, 2012 | 09:03 AM
You can use F-Body calipers on the front, but that only gets your 2 piston calipers, and saves you some weight. It's not a size upgrade.
All the size upgrades are expensive. I don't know much about the rear swaps.
Old Mar 2, 2012 | 09:30 AM
Only real cheap options would be to find a GXP Grand Prix & pull its brakes it has 12.7" fronts & 12" rears but the front Camaro caliper swap is pretty good i done it to mine & it stops great
Old Mar 2, 2012 | 02:12 PM
Silver SLP's Avatar
This sounds like a great summer project! Does the year of the Camaro matter for the swap or is there a preferred year?
Old Mar 2, 2012 | 02:17 PM
98-02 Camaro calipers & brackets, youll have to get the mounting holes re drilled for the montes bolts
Old Mar 2, 2012 | 02:22 PM
Or purchase the ZZP kit that allows the bolts to be used: ZZPerformance - FBody Caliper Install Kit #ZZ-FBCALKIT
Old Mar 2, 2012 | 02:23 PM
Silver SLP's Avatar
I can do that. Thanks!
Old Mar 2, 2012 | 02:26 PM
Dont buy the bolt kit ppl have issues with them, plus a machine shop can drill & thread the brackets for less
Old Mar 3, 2012 | 10:50 AM
elkzzilla's Avatar
so the camaro claiper will give me more stoping power or jst looks if i uses the gxp set up what will i need from the donor car?
Old Mar 5, 2012 | 08:45 AM
elkzzilla's Avatar
Talking
what year would i look for what parts would i need to use GXP grand prix set ups lmk cars on jack wait for brakes:p
