both headlights out at the same time
Old Sep 25, 2010 | 07:46 PM
HPNOTIQracing's Avatar
Default both headlights out at the same time
i didnt find much through the search. so
one night my headlight would not come on but the markers and rears did also high beams. a few minutes later they popped on by them self.
all was good for about 2 weeks then they went out again and not came back on.
i checked the bulbs, fuses, relays, wiggled wires, banged on em, drove down pothole roads and nothing.
driving at night by holding highbeam switch the whole time, at the moment.
any ideas.
Old Sep 25, 2010 | 11:01 PM
lucian*91's Avatar
your drls arnt on at all?
Old Sep 26, 2010 | 12:14 AM
No drls. No lowbeams w/ or w/out switch.
Old Sep 26, 2010 | 11:35 PM
lucian*91's Avatar
wow, this one is tricky, gimme your year, and engine... ill bring up the wiring diagram wednesday and post it on here to see what could be the issue
Old Sep 27, 2010 | 03:09 PM
lucian*91's Avatar
wasnt sure what year, w/e.. so i brought up a 2001 3800..
Old Sep 27, 2010 | 04:02 PM
thanks ill try and look through the wires. its a 2000
Old Sep 28, 2010 | 06:03 PM
now im getting a "high beam out" warning but they still work when i hold the arm back.
Old Sep 28, 2010 | 10:36 PM
lucian*91's Avatar
does your drl relay click? swap it out with a different relay not needed at the moment(fuel pump possibly-just for test), it might be in the turn signal switch, ill try to grab the rest of the diagram 2morrow
Old Sep 29, 2010 | 02:47 PM
drl relay fine just swapped it with fuel pump and still out.
Her_Red_SS
Dec 26, 2014 03:14 AM
labnjab
31
Dec 2, 2010 08:46 AM
S_DAHM
Jul 8, 2009 10:59 PM
Yellow_Monte
Mar 17, 2008 06:09 PM
GrandPaDave
FWD Tech Guides '95-'07
Sep 17, 2006 02:38 AM
