Blowing Hot Air,When It is Off
Where is it set to blow out of when this happens? Face, feet etc. And what is the temperature set at? Once you get up to highway speeds, the air moving across the car will push air through the vent system even if the fan is off.
It will blow from any where, my temperature is set to cold. Yes the air moving across the car will push air through the vent system even if the fan is off. Just sucks because it is Summer time, and having hot air blowing.
Thank you
Thank you
Opinion Needed: Temperature Gauge not working, air blowing hot.
ladytee27
Aug 19, 2015 07:56 AM
