Blower Motor
Old Jul 8, 2012 | 05:41 PM
Silver SLP's Avatar
Default Blower Motor
So every time I turn on my climate controls, i hear an annoying tick like sound, coming from the blower motor.
All speeds work perfectly fine, so I'm wondering if there is any way to tell if it's the blower motor or resistor?
All help is greatly appreciated
Old Jul 8, 2012 | 05:48 PM
MillerMonteSS's Avatar
2010 Monte Of The Year
Old Jul 8, 2012 | 08:19 PM
Silver SLP's Avatar
Thanks man, but I have an 01'
Sorry to mention that before
Old Jul 8, 2012 | 09:07 PM
I'm guessing an '06+ Impala is similar to a '00+ Monte.
First, i don't think it's the blower resistor. I've never heard of those producing an audible sound, they just cause speeds not to work. My guess is the blower motor is on it's way out or something is in there with it (that came in a vent).
To remove the blower motor from our W-Body cars is EASY. Remove the lower passenger side trim panel, underneath there you will see the motor, remove the connector from it and the bolts holding it in and slide'er out. You could then try spinning it by hand and inspect for the noise or cause of noise.
Old Jul 9, 2012 | 08:23 AM
JaxJim's Avatar
Agreed. It could be a leaf or something that got sucked into the fan and is now spinning around making noise. Just yesterday, I cleaned out the blower motor of my '99. There were three or four oak tree leaves in there, making noise. No need to remove the blower motor on mine as it's easily accessible from the outside. I only had to remove the plastic shield at the base of the window on the passenger side to be able to reach into the blower area. There's about a 6" x 4" opening under that grill that leads to the blower - which explains why crap gets in there so easily.
Chevy II
Nov 24, 2007 06:46 PM
MonteRosa
Aug 24, 2007 06:10 PM
willysmith
Aug 20, 2006 04:28 AM
Gr4v3_7
May 31, 2006 12:47 AM
willysmith
Dec 12, 2005 08:03 PM
