blinking lights
Old Mar 12, 2013 | 09:51 PM
boggie's Avatar
Default blinking lights
Hi I have a problem with my headlights I can not turn them on when I do the light in the radio and the dic start to flash they get brighter and flash .I here a clicking sound in the drivers side fuse compartment.have replaced headlights , headlight relay in the side fuse block just replaced light switch still flickers also when the car is off and you pull out light switch it starts clicking on drivers side in that fuse block . Is it possible that the bcm is going bad.
Thank you any help will be great also where is the bcm located
8car2002
Feb 13, 2020 08:48 AM
boggie
Dec 9, 2012 08:51 AM
boggie
Nov 26, 2012 10:01 PM
03BlueMonte
Feb 22, 2010 05:48 PM
bigtire
May 13, 2008 08:43 AM
