6th Gen ('00-'05): Is this a better intake upgrade?
Old Mar 23, 2013 | 05:01 PM
aintnunbutapenut's Avatar
How does this "flashing" work? Does it stretch?
Old Mar 23, 2013 | 05:10 PM
No it's plastic..,I just cut an heated it to bend into shape I needed..
$4.15 /EA-Each
Oatey No-Calk Plastic Drip Edge Flashing
Old Mar 24, 2013 | 10:46 AM
owens91's Avatar
yes & no.
You have it wide open in the engine bay. Even though its set in the fender, or in the open all you're doing is sucking in hot air from the engine that doesn't add too much power. True cold air intakes have a box set up to shield the hot engine air from the colder air coming in.
i was thinking about getting a slimmer filter so it can fit all the way in the fender, once i do that i was gonna find something to cover that part of the fender off leaving the filter isolated in the well....that would make it a full cai right?
Old Apr 3, 2013 | 01:57 PM
yeah definitely!
Old Apr 3, 2013 | 02:06 PM
Those bends and that small of a filter are also a restriction
Old Apr 3, 2013 | 04:56 PM
owens91's Avatar
the bends also has a factor, as well as the size of the filter?
Old Apr 3, 2013 | 05:08 PM
Red Nightmare's Avatar
Just think of water flowing through a tube with alot of curves(like a zig zag). It flows through slower at each curve, now with a straight pipe, or less curves the speed of the waterflow is faster because there is less travel, and its not splashing on every turn(slowing it down)
Also, same with a smaller filter. with the bigger the filter, the more air can fit in it and a larger surface area for air to pass through than a smaller one.
Old Apr 3, 2013 | 05:41 PM
owens91's Avatar
hmmm i see i see thanks for the insight
Old Apr 3, 2013 | 05:43 PM
owens91's Avatar
what type of filter you guys used that fit into the fenderwell?
Old Apr 3, 2013 | 05:54 PM
I was looking at the inside of the fender well just before, & it looks like a good medium sized filter will fit. But the longer the intake tube, the longer it takes for the air to reach the engine, basically making no extra power to what the original makes. Also, with that long pipe sitting in the engine bay its just going to collect heat, making that fresh cold air hot.
Also, if you do decide on going in the fender, invest in a filter screen to prevent water from coming in. something like these... Injen Hydro Shield, Air Intake Shields
well..not specifically those. I've see cheaper.
