Bent Steering Rack
That's what you need inner tie rod ..
You have to remove the rubber boot to remove old tie rod & install new one.
Before tossing the bent tie rod out measure the distance the outer tie rod was threaded onto it and replicate that distance when assembling the new ones. That way it will be approximately the same overall length and close enough to drive the car to a shop for an alignment without too much trouble.
