Bent Steering Rack
Old Jan 7, 2013 | 06:44 PM
killerBee's Avatar
Default Bent Steering Rack
Winter curb hop and damaged several parts. The Steering rack got bent a little. Should i replace it,or just bend it back? I know these can be pretty price`e.Are they easy or hard to install?
Old Jan 7, 2013 | 06:58 PM
What part is bent ? If it's # 12 you can change it ..
Old Jan 7, 2013 | 07:26 PM
Basically:
A cpl mounting bolts,tierod ends, power steering lines...
Easy on easy off...
basically...
Thanks Jerry... Great Post!
Old Jan 7, 2013 | 07:47 PM
killerBee's Avatar
Old Jan 7, 2013 | 07:55 PM
That's the inner tie rod . , You can get a new inner tie rod .
Or you can get a new rack ..
Old Jan 7, 2013 | 08:16 PM
killerBee's Avatar
Where can i order that part? I have looked every were and cant find one.Shop`s keep saying i have to replace hole set up.Im like nope.Thanks for help
Old Jan 7, 2013 | 08:20 PM
killerBee's Avatar
Is this right part? NAPA AUTO PARTS
Part Number: MRC ES3103
Old Jan 7, 2013 | 08:35 PM
That's what you need inner tie rod ..
You have to remove the rubber boot to remove old tie rod & install new one.
Old Jan 7, 2013 | 08:41 PM
killerBee's Avatar
ok thanks man
Old Jan 8, 2013 | 07:22 AM
03SSLE's Avatar
Before tossing the bent tie rod out measure the distance the outer tie rod was threaded onto it and replicate that distance when assembling the new ones. That way it will be approximately the same overall length and close enough to drive the car to a shop for an alignment without too much trouble.
