BCM
Old Feb 11, 2008 | 05:10 AM
bowtietech's Avatar
Default RE: BCM
Here's a bit of advice from a stealership technician..LOL.............Keep in mind that once a BCM is installed into a vehicle and configured it becomes locked.A BCM from a salvage yard is pretty much a paper weight!
Old Jul 6, 2010 | 04:21 PM
TORONTOLSMONTE's Avatar
Default BCM reprogramming, dealership CAN re-program?
So the dealership CAN re-program them ? I.e from the same make/model/year? I would like to try and pick up one and take it to GM for programming but I wanna make sure it can be done first. Might be hard to find the exact same make/model year but i'm sure something is out there. I don't wanna get to a dealership and have them try to give me some line like "sorry we're locked out of an already programmed BCM".
thanks
Originally Posted by lav74
Get a BCM from a wrecker from the same year car... you'll pay alot less. Stealerships don't deserve the extra money. They already got tons of profit from the original sale, and gets lots more on warranty service.
Good luck in your searches.... try car-part.com to start, and find a part nearest you.
Old Jul 7, 2010 | 01:05 PM
revron's Avatar
A previously used BCM can most certainly be re-programmed. If not we would not be able sell Re-manufatured Units from Cardone. AZ can order your BCM for $99.99 $60.00 core. Several different BCM's from several different vehicles will interchange. After you buy a new BCM you need to either go to a Dealer or Shop and have it programmed or have a buddy with HPTuners do it.
Just be certain to match the OEM part number on your BCM up to the used one you pull from a yard.
Old Jul 8, 2010 | 11:47 AM
bbengineer's Avatar
No, a used BCM cannot be reprogrammed (after a certain number of key cycles). It is a paper weight at a dealership at that point
Reman/Refurb BCMs (sold by parts stores) are sent back to Motorola (or other authorized reman house) and are wiped out so they appear as new to the Tech-II.. at that point they are no longer 'used'
The only BCMs that will work are the 00-05 Impala & Monte Carlo
HPTuners cannot program the BCM in these cars... only a GM MDI or Tech-II can be used
And why bother with a reman BCM for $100 + $60 core when you can get a new one for that price? (We have a vendor over at NAIOA.com that sells GM parts at a good discount)
BBEngineer
Old Jul 8, 2010 | 11:49 AM
Great to see you on the MCF BBE
Old Jul 8, 2010 | 11:51 AM
bbengineer's Avatar
Thanks... I've been here a long time (appears longer than you ).. I just don't post much
BBEngineer
Old Jun 8, 2011 | 02:38 PM
revron's Avatar
BBEngineer
Bought one from a local boneyard. It came off of a 03' chevy 1500. Had it installed and reprogrammed at our local dealership for $120. It didn't fix the problem though( turns out its the Theft module)
My point is that the BCM worked.
Old Jun 8, 2011 | 02:52 PM
bbengineer's Avatar
And nearly a year later... what does a Chevy Full-Size pickup BCM have to do with the BCM from an Impala or Monte???
You cannot reprogram a used BCM for an Impala or Monte...
BBEngineer
Old Sep 5, 2011 | 10:02 AM
d3adpool's Avatar
I tempted to try this as i have a 2001 impala where several things are going crazy such as the a/c shuts off, radio, chimes, gauges die, service vehicle soon light, low fuel light, battery light, and headlights shutting on and off are happening. I can get a bcm at my local pull it yard for about 25 dollars, has anyone else gotten a used bcm reprogrammed for a monte/impala? it must be possible or why else would u see so many for sale on ebay and car-part.com and several other places?
Old May 27, 2013 | 07:03 PM
Tevin FS Blalark's Avatar
Default 2007 monte carlo ss
Hey guys my 2007 monte carlo ss decided it wanted to go in to theft deterrent system mode and my key wont turn back all the way ive been looking for a bypass because I dont feal comfortable paying chevy 350 to fix it , I was wondering if anyone has similar problem and can help thanks
