BCM
Old Feb 5, 2008 | 02:52 PM
1stz51's Avatar
Default BCM
2001 SS Where are the BCM and the ignition control module located?
Old Feb 5, 2008 | 03:19 PM
Default RE: BCM
Hi Bill, I searched for the location and could not find,
but I'm sure `if you are patience that one of
our expert members will post it.
During my search I did find the below infor.
Hope it helps in some way ?
Good Luck
Hi
Unless you have a Scan tool with GM TIS2k programming abilities, you'll need to have the BCM reprogrammed at either a dealership and or a repiar shop with reprogramming capibilities.
Here is the EXACT GM replacement and reprogramming procedures, if intrested.
Important:
• Read this procedure carefully and completely.
• The BCM will not function properly if the Setup New BCM procedure is not performed.
• Perform the Programming Theft Deterrent System Components procedure after successfully finishing the Setup New BCM procedure. Refer to Programming Theft Deterrent System Components in Theft Deterrent. If the procedure is not performed after a BCM replacement, the following conditions may occur:
- The vehicle will not be protected against theft by the Passlock system.
- The engine will not crank or start.
Connect a Scan Tool (Tech 2) to the Data Link Connector (DLC).
Turn the ignition switch on.
Select Diagnostics and input all of the required data when prompted by the Scan Tool (Tech 2).
Select BODY CONTROL MODULE.
Select SPECIAL FUNCTIONS.
Select Setup New BCM.
Note, Input all of the required data when prompted by the scan tool.
Select Setup SDM Part Number in BCM, and follow the onscreen directions.
Select New VIN, and follow the onscreen directions.
Select Option Configuration, and follow the onscreen directions. .
Select Point of Sale, and follow the onscreen directions. .
Exit back to the SPECIAL FUNCTIONS menu.
When the BCM, VIN, Point of Sale and Option Configuration have been entered, proceed with the Theft Deterrent Re-learn procedure.
If the scan tool displays UNABLE TO PROGRAM BCM. BCM IS SECURED, then the BCM must be replaced and this procedure must be repeated on a new BCM.
NOTE: After the completing the above procedure , personalization of the BCM defaults to default settings. Inform the customer that the personalization settings must be reset.
Important
After programming, perform the following to avoid future misdiagnosis:
Turn the ignition OFF for 10 seconds.
Connect the scan tool to the data link connector.
Turn the ignition ON with the engine OFF.
Use the scan tool in order to retrieve history DTCs from all modules.
Clear all history DTCs.
Hope this helps someone [8D]
`Space
Old Feb 5, 2008 | 03:30 PM
Default RE: BCM
[align=center]Bill, I found the below in my Search[/align][align=center]I thought you or other members with the 2001 Monte Carlo[/align][align=center]may find of interest.[/align][align=center][:-][/align]
2001 Chevrolet Monte
Technical Service Bulletins
http://www.carcomplaints.com/Chevrol...001/tsbs.shtml
[/align]
Old Feb 5, 2008 | 05:02 PM
1stz51's Avatar
Default RE: BCM
Space,
Thanks for the helpful info on the TSBs. Maybe this will give me some ammo
when i take it to the dealer!! LOL,
Old Feb 6, 2008 | 07:07 AM
bowtietech's Avatar
Default RE: BCM
ORIGINAL: 1stz51
The BCM is located in the area above the parking brake pedal.It is a black box with 3 electrical connectors. The ignition module is located on the engine.The ignition coils are mounted to it.Just follow the spark plug wires to the end that is not attached to the spark plugs and you are at the ignition coils.
Steve.....aka bowtietech
Old Feb 6, 2008 | 07:17 AM
Default RE: BCM
Hi `Steve, thanksfor posting yourinformation for
a member.
It's great to have you here on the MCF.
Wish you a `Happy Day,
`Space
Old Feb 6, 2008 | 04:29 PM
1stz51's Avatar
Default RE: BCM
Thanks bowtietech, i just went out to check wiring to these
everything looked good, i guess i am off to the dealer to get
it checked out,i am betting on the bcm since it starts when it
wants to and half the time i have no gauges,traction control,
radio etc. etc. the big kicker is when i shut it down the
security light comes also a service vehicle soon comes on.
Every thing i have read points to the bcm. My guess is 500$
to replace and reprogram, does that sound about right?
Old Feb 7, 2008 | 04:27 AM
bowtietech's Avatar
Default RE: BCM
[quote]ORIGINAL: 1stz51
Thats about right.
Steve
Old Feb 7, 2008 | 10:53 PM
lav74's Avatar
Default RE: BCM
Get a BCM from a wrecker from the same year car... you'll pay alot less. Stealerships don't deserve the extra money. They already got tons of profit from the original sale, and gets lots more on warranty service.
Good luck in your searches.... try car-part.com to start, and find a part nearest you.
Old Feb 10, 2008 | 07:19 PM
04 Intimidator's Avatar
Default RE: BCM
X2. You can also check ebay if you can't find one in the boneyard.
