7th Gen ('06-'07): Bad electrical problems possible ecm fried HELP!!
Old Aug 16, 2022 | 09:06 AM
Mach33n's Avatar
Default Bad electrical problems possible ecm fried HELP!!
Okay I had a loose connection on my starter for a while sometimes it would just click but I couldn't see what was loose so I would just jiggle the wires and kind of get them wedged in there amongst the refrigerant lines. (I know I know I learn the hard way). So one day I ran over a small curb and apparently the post broke off of the starter and arked on the engine I had it towed home 50 miles for $300 thank God for gas prices. And I got it to start by jumping the S wire around the starter to the hot it won't start any other way and it goes in the limp mode and throws all kinds of error codes like it's like my mass airflow sensor and manifold absolute pressure and it says voltage circuit openNow I started by cleaning up my maf sensor but I'm almost positive it's an ECM issue how can I determine this? I know it was draining the battery in almost 5 minutes I did do a short circuit test by hooking a voltage meter or a little test light up to post on the negative and then my battery and I pulled fuses until I saw the light dim and that happened on 2 different fuses the 60 amp battery 2 and a 60 amp battery 4 I've been tracing those wires down to find the source of the short I found some burnt Wires in theFuse boxing the passenger side kickwell where you had to pull the lever off of that connectorA large gauge purple wire has burned marks all around Inside wear it connects in the connector but not on the wire anywhereSorry for jumping around I'm sure I have all sorts of problems problems but it's my only transportation and I need to get this fixed up I haven't been mobile for about 2 months now
Old Aug 21, 2022 | 09:36 AM
Honestly, you may have a damaged PCM or more from that arcing issue. If you haven't done so already, I would advise taking it to a shop capable of doing some diagnostics on the car as this sounds a bit involved for Internet forums to review.
xpage
Apr 4, 2022 10:59 PM
Overdose666
Aug 20, 2013 08:48 PM
383strokinit
Jan 29, 2012 07:56 PM
Awalk06
Sep 24, 2009 04:57 PM
ilitrit
Feb 9, 2007 04:38 PM
