auto dimming rear view mirror wont work
Old Dec 31, 2009 | 07:16 AM
kastanza's Avatar
Default auto dimming rear view mirror wont work
I took my 00 Monte into the dealership to have them fix my blower motor resistor and when I picked it up the auto dimming rear view mirror light will not turn on. I am wondering if there is a fuse for this or if you have any other ideas that I can check to get it working again.
Oh yeah, both lights on the mirror work just fine. I dont know if that matters or not.
Old Dec 31, 2009 | 07:55 AM
Make sure the button is turned on in the center... And then play with the wire a little bit. See if the light pops on. Mine got messed up from heat and stuff and now I have to fiddle with the wire sometimes for the mirror to work right.
Old Dec 31, 2009 | 08:00 AM
kastanza's Avatar
I tried pushing in that button 10 times on the way to work this morning when someone was riding my *** and blinding me. I also tried moving that wire that runs up the windshield a little to to see if I could get it to come on but no luck.
Old Dec 31, 2009 | 08:11 AM
Yeah sometimes I have to like... squeeze the wire, and move all the wires inside it some to get mine to pop on. It's a pain, but I'm too lazy to cut it off and piggy-back in a new wire.
Other than the mirror itself being bad, I'm not sure. Because obviously the mirror is getting power
Old Dec 31, 2009 | 08:27 AM
kastanza's Avatar
Tru dat. Ill try wigglin some more and see what happens. Thanks for you help pal
Old Jan 4, 2010 | 03:11 PM
kastanza's Avatar
Wigglin the wires did the trick. Thanks for the help!
Old Jan 4, 2010 | 03:15 PM
Glad it worked for you
Unfortunately unless you actually cut it and put in new wires you may have to keep playing with those. Luckily mine has stayed on for a good month, but my map lights now won't work unless I touch the wires. It's a pain, but it's better than paying for something else right now!! aha
Sciggy
Mar 24, 2010 02:35 PM
nitehwk10
Oct 31, 2008 11:50 AM
willeatforfood
Mar 31, 2008 06:10 PM
sorcier11
Mar 20, 2008 01:02 PM
jay26
Jul 15, 2007 04:59 PM
