6th Gen ('00-'05): Airbag light on AND no sound from radio
Old Mar 29, 2019 | 03:57 AM
Kendall13's Avatar
Default Airbag light on AND no sound from radio
So, I would never have thought that these two parts might be related, but every time the airbag light comes on, the factory radio puts it so sound. The radio is on, I mean illuminated and can be adjusted, but puts out no sound. Sometimes they both work, but lately it's worse. Any thoughts? Thanks.
Old Mar 29, 2019 | 11:30 PM
I would start with having someone with a good scan tool check what the air bag code is popping up for. Most cheap scan tools are unable to report those codes, so you might need a dealer with a Tech II scan tool to read it. From there, see if you can resolve that issue. Curious if it's a coincidence about the radio and air bag issue or if there is a short in the wiring crossing both items. My hope is the air bag code leads to a solution that somehow solves both issues.
Old Apr 1, 2019 | 08:47 AM
Kendall13's Avatar
Thanks. I have had someone trace the issue to the module under the passenger seat. I was mainly wondering if anyone had ever seen the two issues tied together.
DCMoose48
Apr 22, 2014 03:07 PM
godfather202
Mar 20, 2014 10:53 PM
xpage
Nov 12, 2012 12:31 AM
Ric91stang
Nov 29, 2011 10:53 AM
terrell293
Apr 30, 2010 09:02 PM
