Air conditioner help
I have a 01 SS and the AC is not working. I was getting nothing on the high or low pressure side. I added Freon and low pressure went to 35 lbs high had almost nothing. Is the whole front of the compressor the clutch? Should what appears to be the clutch on the compressor spin when it is engaged? It doesn't look like the clutch is engaging when I turn the AC on. The only fuse I found was a 10 amp labeled ac comp. in the box under the hood which was ok. Is there another fuse or relay anywhere?
Thanks
Thanks
Thanks
Thanks
I don't mean to jack ya thread, hoping someone has some information for both of us.
well first of all unless u r a certified a/c tech u r not allowed to open ur a/c system. second make sure you are actually using the right "freon" (r-134a?) and there is also oil in the system. third you will hear your compressor come on...all in all take your car in and get it checked out
