Air conditioner
Kits with and without sealant are readily available from any parts store and it is ridiculously cheap in the US. Once the hose is hooked up, you charge the system with the engine running, A/C on full. It takes only a few minutes and its easy to figure out the hose because the quick connect on it won't connect to anything but the correct "low side" port (this does not mean that it is located down low).
I would never use the freon with the sealers in them. They will eventually end up ruining your system and then it will cost big bucks to get it fixed. That sealer goes everywhere, just not where a leak is. It doesn't take much to clog up an evaporater or condenser or even the orifice tube.
Wayne
Wayne
