aftermarket cat causing problems?
Old Jan 22, 2008 | 10:19 PM
2000LS's Avatar
Default RE: aftermarket cat causing problems?
post cat o2 has nothing to do with engine performance or mileage, its only purpose is to monitor the converter.
Old Jan 23, 2008 | 01:36 PM
1977Monte's Avatar
This is the reason aftermarket high flow cats only have a two year warranty.. they don't put anywhere as much material in the cat as opposed to a stock cat.. They will be used up by that period and you'll need to purchase another... That also why a stock cat is so expensive too.. they have more of the precious materials inside that are used to "clean" up the exhaust.. If you want trouble free then a stock one would be best bet as it should last much longer (assuming the car is in good tune) ..
Old Jan 26, 2008 | 02:42 PM
splendidkiller's Avatar
well i'll just probably end up making it a straight through
Old Feb 10, 2008 | 06:55 PM
04 Intimidator's Avatar
Actually you have a few options.
1 - emulator - this will work fine for your engine and model year.
2 - code reader - you can get these for 70 to 100 bucks and it will read the code and you can delete them. Anytime a P0420 comes up, just delete it.
3 - HP Tuners - get this equipment for 400 bucks and you can simply remove the code completely from the lineup and not worry about it at all. You can also tune your vehicle as well if you are going for performance in the future.
NovaSS369
23
May 25, 2011 10:48 AM
monte2001carlo
Jan 16, 2011 10:12 AM
l0gitech87
Nov 26, 2010 02:17 AM
rolandemartinez
Oct 2, 2010 02:17 AM
manningwill
Mar 30, 2010 09:07 AM
