Add fog lights
Old Apr 10, 2010 | 02:41 PM
monte07's Avatar
the vin said it is a ls and the sticker said it is a lt and has the base lt things exept for the radeo controlls on the wheel.
Old Jul 7, 2010 | 02:48 PM
sportz's Avatar
I have a question; Is it possible to put aftermarket fog lights in the stock locations. If so, what size fits? I don't have a factory wiring and switch but wiring in a switch for them should be no problem.
Thanks
Old Jul 8, 2010 | 09:44 AM
RickAKATed10's Avatar
Photobucket
Get a tape measure and... measure. I'd guess it's about a 3 and a half inch opening.
Old Sep 2, 2010 | 06:42 AM
mmient's Avatar
I have the 2007 with the vents in the fog light holes. Do the replacement lamps mount to the existing brackets or are there additional mounting parts needed?
Old Sep 3, 2010 | 07:56 PM
monte07's Avatar
the vent holes pop out and the fog light brakets and fog lights pop in where the vents were i got a whole wire harness go to shorts when i started to use the fog lights. so i would double check the wires before using the lights to make sure there is no problems if you need the fog light switch combo you can use the same year impalla head light fog light switch they work the same and are the same. same as the fog lights.
rg9johns
Aug 22, 2014 10:46 PM
guzzimane
Apr 27, 2014 10:02 AM
dc1
Nov 9, 2013 01:48 AM
monte07
Apr 12, 2010 06:22 PM
YaBoyMartell
Nov 23, 2009 07:25 AM
