AC Vents
Old May 31, 2010 | 03:16 AM
willyking's Avatar
I don't have that problem, my recirculating air doesn't work, the light comes on but nothing happens, my A/C is on and selector is on vent. I changed the cabin air filter, took out the fuses and still nothing, any ideas would be great short of replacing the valve I've run out of ideas.
Old Jun 30, 2010 | 09:18 AM
widebody's Avatar
This must be a common problem. I've been trying the last few days to fix mines. The driver side is doing the same thing and i've checked the actuater which is working properly and i also took the actuator off and manually moved the blend door to the cold position and it still doesn't get cold while the passenger side will freeze you. My car didn't come with an owners manual is there anyway you can tell me which fuse is the hvac fuse maybe even post a pic so i know which fuse to pull. Thanks alot
Old Jul 1, 2010 | 03:16 AM
lucian*91's Avatar
if i had access to the gm sevice information i could atleast check the techinacl bullitens to see, but sadly i dont have access to that right now. im guessing its common now, and im sure its in gmsi tb's...
Old Jul 3, 2010 | 12:50 PM
word1120's Avatar
lucian*91 do u have access to things like tech info? that would be very helpful??
Old Jul 4, 2010 | 02:52 AM
lucian*91's Avatar
naw, it will be a couple months still. so basically air conditiononing wont be needed as bad by then..i was just saying i wish i had access to it right now
Old Mar 19, 2018 | 06:56 PM
rcgray48's Avatar
Hello Justin,
Can you please help me? I am having the same problem, and would really like to use your relearn method. I just checked my owners manual for my 2006 Monte. Unfortunately, I can't find the "HVAC" fuse. I see a fuses for the various fans in the fuse box under the hood. I just can't locate one with the name "HVAC". Would the fuse you're suggesting be listed as another name?
Thanks,
rcgray48 (Bob)
Old Mar 20, 2018 | 09:48 AM
Originally Posted by rcgray48
Hello Justin,
Thanks,
rcgray48 (Bob)
You may be better starting a new topic.. This ones pretty old and may not be the same issue youre having.. Until someone else can help tho, I might suggest unhooking the battery for the amount of time.. I would assume that would have the same effect..
ROY6265
Apr 10, 2011 03:54 PM
sunshine1979
Oct 28, 2010 06:50 AM
NYGiantsfan
Sep 9, 2010 04:20 AM
Doug g
Jun 24, 2009 04:09 PM
S_DAHM
May 20, 2009 07:03 AM
