AC Vents
Old Apr 14, 2010 | 04:36 PM
Dcbank's Avatar
Default AC Vents
When I turn my Air on cold air only blows out on the passenger side, but not the driver side. Had my system check out and they didnt detect any problems with my system. is there a main vent inside the dash thats close off thats stopping cool air to blow through the driver side vents?
Old Apr 14, 2010 | 06:20 PM
aussiek2000's Avatar
Does any air blow out the driver side? It could be a diverter door.
Old Apr 14, 2010 | 07:02 PM
Justin Knight's Avatar
if your car has dual zone (which it probably does) i don't remember the exact procedure but i think if you pull out the HVAC fuse from drivers side fuse panel for 15 mins it will relearn the HVAC motor doors when you put it back in and start the engine. there are seperate blend doors for each side and are operated by small dc motors . they are around $140 and are mounted on the side of the HVAC box under the dash. try the fuse thing first and see if it relearns its position.
someone with a tech 2 scanner can diagnose this very quickly.
Old Apr 15, 2010 | 03:51 PM
Dcbank's Avatar
Yes its blowing on the driver side but its like the cold air is being blocked off. Its not as cold as the two vents on the passenger side.
Old Apr 15, 2010 | 07:52 PM
try the relearn and if it doesn't work put the blower on the lowest fan setting and move the drivers side temp slider, listen for the motor moving the door.
and if you havn't changed your cabin filter in a while do that too. if neither of those help i can't guess which thing to tell you to try i would need to see the car but i doubt your close to hamilton, ontario.
Old Apr 16, 2010 | 12:24 AM
Dcbank's Avatar
Default Ac vents
When I adjust the the driver temp slider it gets hot when I move it to the red but when I move it down to the cold blue side it doesnt get as cold as the two vents on the passenger side.
Old Apr 17, 2010 | 02:02 PM
okay for the last time have you tried removing the HVAC fuse for 15mins and then trying is so it can relearn? if you don't do the relearn i'm not even gonna try and help you anymore
Old May 30, 2010 | 07:24 PM
willyking's Avatar
2005 monte carlo no fuse that says hvac
Old May 30, 2010 | 08:38 PM
word1120's Avatar
i have the same problem and i have a 2005 monte. but instead the passenger center is the only one that blows semi cold. the other 3 just blow warm??
Old May 30, 2010 | 09:13 PM
word1120's Avatar
After the 15 mins. how long does it take to relearn? Do I have to drive for it to relearn or what?
