AC drain clogged?
Old Sep 13, 2010 | 04:01 PM
One Dark SS's Avatar
Default AC drain clogged?
I have water (pretty damn clean)driping down the carpet on the passenger side, seems to be coming directly from the blower motor and only leaks when the AC is runing, which leads me to beleive the drain is clogged up.
Any know easiest way to access this so i can clean it? or any input on what else it might be?
Old Sep 13, 2010 | 09:49 PM
JaxJim's Avatar
If it ain't raining, and you have a water leak, it must be the A/C. There's probably a rubber drain tube on the firewall somewhere. If you find it, stick something in there to unplug it. I think someone did a writeup on this in one of the how to sections. Not sure which generation it was, but all are probably a similar set up.
Old Sep 14, 2010 | 06:55 PM
Thanks man, found the thread;
https://montecarloforum.com/forum/sh...ighlight=Drain
imma go try that out right away!
Old Sep 14, 2010 | 07:14 PM
If that corrects the problem please let us know, thanks...
Sunmonkey
Nov 19, 2013 08:50 PM
dave11
Sep 26, 2012 04:57 PM
Franks 03SS
Jul 3, 2012 01:18 PM
apguy
Mar 18, 2011 02:23 AM
LW57912
Sep 1, 2010 10:26 AM
