Intake manifold pressure--clogged converter?
Old Sep 26, 2012 | 02:55 PM
dave11's Avatar
Default Intake manifold pressure--clogged converter?
I've got an '02 3.8 liter with 76K miles. Past week has suddenly lost power on hills and on quick starts. Otherwise runs fine, no DTCs.
Hooked a vacuum gauge to the intake manifold. At idle, it reads 20 inches vacuum, steady.
On quick accel to 3000 RPM, the vacuum drops quickly to as low as 5 inches, but within a second, comes back to 20, maybe 21-22. The gauge needle starts shimmying at that speed though, and not from the vibration of the car.
I never see the slow drop in manifold intake vacuum that is said to happen with a clogged converter. But since failing converters are so common on this vehicle, it still seems to need looking into.
Does anyone have any experience with this?
Thanks.
Old Sep 26, 2012 | 03:07 PM
You could try temporarily unhooking the exhaust downpipe and seeing if the bogging went away.
Or you can have an exhaust shop do a back-pressure test
Old Sep 26, 2012 | 03:13 PM
dave11's Avatar
My question is about the intake vacuum, and what constitutes a normal or abnormal reading.
Old Sep 26, 2012 | 04:57 PM
those vacuum pressures seems normal....
raised at idle and fall during acceleration....which is normal....also vacuum varies while driveing....
Im with mike on this one(chibi)....get the back pressure checked...or disconnect the down tube..to see if power gets restored....
Sunmonkey
Nov 19, 2013 08:50 PM
Franks 03SS
Jul 3, 2012 01:18 PM
apguy
Mar 18, 2011 02:23 AM
One Dark SS
Sep 14, 2010 07:14 PM
LW57912
Sep 1, 2010 10:26 AM
