ABS Traction Light and Brake light
Old Feb 18, 2011 | 02:08 PM
smartin40's Avatar
Default ABS Traction Light and Brake light
Hi. I am an idiot with cars and could really use help. I have a 2003 SS and a few months ago took it to a dealer as the car "stuttered" when driving and the brakes felt "funky." Anyhow..$800 later, they did a "hub bearing assembly"; "driver's front axle" and other unrelated things. Well, my traction light and brake lights have stayed on since a month after I had the repairs done...and now, literally, when i go to brake it feels as though the brakes are "pushing back" at me and really feels like they are just gonna totally fail. Paperwork says the work they did is guaranteed for 12 months so i am still under that. Do i have the "right" to call them and tell them i don't think they fixed anything? I am sorry to ramble...i am a girl, i am clueless about cars and i really dont want to be "screwed" by this shop when i call to see if i can bring it back and have them FIX it this time. I hope this makes sense...and THANK YOU for any guidance you can give me. Susan
Old Feb 19, 2011 | 08:41 PM
Does your red BRAKE light come on?
If so I would check your brake fluid and top it off if it's low. and possibly get your brake fluid flushed, bled, or changed.
Old Feb 20, 2011 | 10:56 AM
mightygmen's Avatar
When did the light come back on? You stated that "stayed on since a month after I had the repairs done..." What do you mean? It's been on for a month or it's been a month since it came on? Why didn't you go back right away? $800 buck? What did they find wrong to begin with? I would most definitely go back and try to explain what it is doing. Words like "funky, and stuttered" wont really help with the mechanics. Describe when and how the car drives. At what time does this do that? What rpm, speed etc.
If what they did didn't fix the problem to begin with they are obligated to fix it right. If after they worked on it and a month later something else happened, they may charge you more. I would also do a code search. See what is coming up and do a google search. Going into a dealership/repair shop without a clue as to what sensor is bad will almost always mean more money!
mwmarshall
May 14, 2022 02:43 AM
hotrodharley
Nov 15, 2013 11:37 AM
Chris s
Jan 27, 2013 04:30 PM
heartbeat
Jan 14, 2012 10:47 PM
irulesoha
Aug 19, 2010 02:32 PM
