THE "ABS - Traction Control" Problem
Old May 22, 2009 | 05:43 PM
TKG2000's Avatar
Corey,
Glad you got it!
RPD,
What is the latest?
Old Sep 8, 2009 | 11:34 AM
tlynn721's Avatar
Default My "Service Traction System" comes and goes
I've been having this problem for several months, although it's inconsistent. Sometimes the light comes on, sometimes it doesn't. It actually began after I got my LF hub replaced. The sensor was checked and found to be a little loose so it was popped back in (these are not my words...mechanic). The light stayed off for 2 weeks and is back on again. No way I'm replacing the hub again after only 3 months. Could it possibly be anything else?
Thanks!
Old Sep 10, 2009 | 03:06 PM
Crazy Corey's Avatar
I still get it from time to time, I've noticed it tends to be when my voltimeter on the dash drops below a certain level. Do you notice the same?
Old Sep 10, 2009 | 07:52 PM
wnmech's Avatar
I also have a similiar thread I just posted before I was this on going thread. I also could not get a code from my normal obd2 scanner and I have the trac/abs intermittent light on. My car is currently a chevy awaiting their diagnose soI can repair it myself. How is it that the rear sensor can cause a traction light? I thought you get the traction light if your front drive wheels break loose
Old Jul 28, 2018 | 07:38 PM
Ace25's Avatar
I too, don't mean to "car jack" a thread that's 9 years old... However I did find good info here, it just wasn't my problem... Mine didn't throw any specific wheel codes, just the generic ABS code. I'll link this thread on the forms in case others find it useful:
https://montecarloforum.com/forum/mo...88/#post713143
BGraham10
May 8, 2016 06:40 PM
Warhorse
Apr 23, 2016 08:01 PM
Exerstine
Jun 16, 2009 11:28 PM
AwesomeSS
Apr 21, 2009 02:15 PM
mavrickf1613
Apr 9, 2009 09:12 PM
