6th Gen ('00-'05): abs and traction control light come on
Old May 15, 2014 | 10:05 PM
ohara's Avatar
Glad to help, just hope it is what you need to get everything fixed. I have been in the same situation and members on the forum have come to my aid, so it is the least I can do to return the favors I have received.
Best of luck and let us know if you get it fixed
Old May 17, 2014 | 04:11 PM
Aaron0313's Avatar
Not sure about up in Canada but here in the US a lot of the auto parts stores have a hand held scanner capable of reading the ABS code. You might want to call around and then next time the light is on, swing into one, and have them read it. That way you know what wheel to focus on or if it's something like a bad ground for the EBCM/pump.
Old May 18, 2014 | 10:37 PM
terr's Avatar
hi,yes i do have a scanner for abs,and its telling me its the right front,dtc codes:c1216,c1222,c1233,as far as the ground,I never thought of that,i'll keep that in mind,anything is possible,thanks for the advice
Old Jun 1, 2014 | 09:54 AM
terr's Avatar
All it was is the abs wiring harness,Thanks to everybody for their help!
Old Jun 2, 2014 | 06:34 AM
Nightmagic11801's Avatar
i mentioned this is my first reply.....
Originally Posted by Nightmagic11801
check all the wiring for each hub first. then check for ground wires near the abs pump and in front of the engine.
Old Jun 2, 2014 | 01:19 PM
terr's Avatar
it wasn't the ground,it was the pigtail wiring harness,having a bad day??????????
Old Jun 3, 2014 | 08:14 AM
lol!!! are you asking me if im having a bad day? no, i wasn't. i was just pointing out that i told you to check grounds before is all. i left the cool smiley guy at the bottom so you didnt assume i was mad or anything. glad you got it figured out. the hub systems on the montes are a pain in the ****. and when it comes time to buy new hubs...spend the money on the expensive ones with the longer warrantys...its worth it. ask anyone here
Old Jun 3, 2014 | 10:12 PM
terr's Avatar
no problem,yes I've read that most people on this forum recommend timken bearings,which I agree,but the best I can do locally,unless I order them from another province,is moog hub bearings,with a 3 year warranty,for about $230.00 a piece,or skf bearings with a 1 year warranty,obviously I'd go with the moog for the warranty,what would you recommend?
Old Jun 4, 2014 | 06:09 AM
moog is a great brand yes and if you have the money to buy them sure. but a brand that i feel is just as good and half the price is Timkin. autozone sells them. they have a 3 year warranty as well. ive had good luck with these so far.
mwmarshall
May 14, 2022 02:43 AM
that silver monteSS
May 4, 2015 08:13 AM
Chris s
Jan 27, 2013 04:30 PM
strypergt
Aug 3, 2011 09:08 AM
Bob50th
Jan 7, 2006 09:46 AM
