Abs/traction control issue
Old May 23, 2021 | 02:04 PM
fredkuhn's Avatar
Default Abs/traction control issue
My 2005 LT has abs traction control lights on. Bearing was replaced one year ago with factory ac delco. I have good resistance at sensor and voltage at harness. Compared with other side. My Autel scanner says right front wheel. Any ideas?
Old May 23, 2021 | 06:47 PM
craig32's Avatar
Mine is the same way, has to be the wiring to the sensor. I just got used to the bells and whistles, and the light being on.
Old May 23, 2021 | 10:05 PM
fredkuhn's Avatar
yes, I heard about the wiring issues. Just weird it tested the same as the other wheel. I wiggled all of it and no change on meter. Thanks for reply
Old May 28, 2021 | 05:32 AM
gtr25's Avatar
Check the harness slack on the claimed bad side with the wheel turned full to both sides. I had 1 where it was too taught and light would kick on from pulling on the wires. Made it a year or so after i rerouted wire for slack before connector went bad. Make sure u test resistance on bearing plug while spinning. I had 1 floated all over then dashed out when spinning fast by hand. Checked good static and slow.
GTHSS
Sep 16, 2018 07:31 AM
claydoh
Oct 1, 2016 12:08 AM
Storman1
Aug 22, 2015 08:54 AM
1sickazmonte
Sep 17, 2008 01:03 AM
