ABS Light On - Traction Off - Service Traction System
I had the ABS/ Traction Service light problem when I bought the car, guess that is why the Dealer unloaded the car, was going to send it to Auction. Along with the check engine light. I was lucky and dodged the $400 bill for am new wheel bearing, my mechanic found the RR sensor unplugged, plugged it in, cleared the code, gone. The check engine was three codes, purge solenoid, tank pressure sensor and fuel level sensor. I replaced the purge valve along with the vacuum tree to the intake and the pressure sensor, about ten miles the check engine light went off. I have to replace either the level sensor or put in a new fuel pump. I am giving the fuel pump/tank the Marvel Mystery Oil treatment, going to use a 32oz bottle, four oz at a per ten gallons of gas, might clean the fuel tank and level sensor, if not after the bottle gone; I'll decide whether to replace or repair fuel pump. I already have almost $50 in the tank pressure sensor, you get a new one with a new fuel pump, another $50 for a level sensor and got to pull the pump. I anyone needs to get the check engine light cleared, buy a new pressure sensor, should turn off engine light if it that is what is coding, for emission inspection.....
Having the same issue on the '00 SS. Trac off, ABS and Service Traction System lights. Hooked up the Tech 2 and got DTC C1218 "Pump Motor Circuit Shorted to Voltage or Motor Ground Open". Did some research on YouTube and found this video:
GM ABS code C1218 diagnosis: 01 Chevy Impala - YouTube
After watching I wiggled the connector into the EBCM and all lights and DTC cleared. Just a loose or dirty connection. I will be unplugging the connector and give it a good cleaning this weekend.
Here's a couple good videos on the subject and how to test the harness(s):
How To Fix ABS & Traction OFF / Service Traction System Light Monte Carlo Chevy Impala Buick Century - YouTube
ABS Light and Traction Control Off Indicator - 2004 Chevy Implala - YouTube
Glad you found the issue but something else might be off in my experience. Whenever that has happened to me, either a tie rod was off or an axle cv boot was ripped and destroyed the wiring due to bad alignment. Also sometimes those ****s just get old and brittle. Just make sure you have good clearance when you reinstalled them.
Wow, been a minute since you have posted on here. You still have your sic tricked out Monte? We should try to meet up some time, being this close and all. Remember you were into motorcycle racing etc. and were slowing down with the Monte. You do have a special car, you built it back in the day when one could get nice aftermarket parts and then did one off Wilwood brakes etc. (I'm jealous about those).
Recently was getting light on light off some noise from ABS my solution was 2 fold
i replaced the hubs that resolved the ABS and noise.. I had a dragging bearing The other was intermittent. Replaced both harnesses on the front problem solved. Freedom for 2 weeks now . good luck
The brake setup, you wouldnt love if you've seen the bills for maintenance and such. The rotors alone are insane! Pads are not so bad but don't get me started on the calipers! Lol
michelob
Apr 16, 2014 10:05 PM
teamfbody
34
Aug 11, 2013 08:22 PM
Chris s
Jan 27, 2013 04:30 PM
Jokers1995
Jul 31, 2012 09:11 AM
