99 Monte Carlo steering column replacement-VATS problem
Old Dec 16, 2006 | 12:32 AM
krandall's Avatar
Default 99 Monte Carlo steering column replacement-VATS problem
I bought a 99 monte carlo theft recovery. They pretty much stripped the whole car. I replaced the motor and trans with the computer from a donor car. They broke the steering column and messed up the ignition switch. I am going to replace the whole steering column from another car. Does anyone know what I would also need so it will start, because of the vats system ?
Old Dec 16, 2006 | 07:24 AM
04 Intimidator's Avatar
Default RE: 99 Monte Carlo steering column replacement-VATS problem
If you can, get the "WHOLE" steering column system... Including the wiring harness. You can have the ignition either rekeyed or use your old ignition.
erosem21
Apr 3, 2012 02:52 PM
sws2000
Apr 24, 2009 11:27 PM
teddy620_2000
Oct 9, 2007 06:15 PM
locs650
Oct 14, 2005 08:46 AM
